factory rims. no issues.
I have OEM 22's,with the factory Bridgestones needing to be replaced at 59k miles. Based on what I read here I ordered 285/45/22 Michelin LTX's from Sam's Club. When I went to have them installed this morning Sam's Club wouldn't do it, they refused because they are not the OEM spec tire in their computer (265/50/22). I'm hoping my local tire shop can get them on before the end of the day today. Michelin LTX Premier's were $265/tire. $1200 with tax.
OEM tire is 275/50/22. The OEM size you mentioned was in their is 265. That is not the OEM size we have on our cars. So, I am guessing you may have made a typo error here. If not, then their number from their computer is definitely wrong.
Discount tire recommends 2 alternative sizes to the OEM size. The 2 alternatives from discount tire are:
285/50/22
305/45/22
But you bought 285/45/22. I don't know, maybe even a company like discount tire may refuse to sell put those tires on your car. For the simple reason that it does not show in their computer as an alternative size. Or do you have any literature that shows that size could be used? Because if not, it means anybody can just choose any size to put on their car, just because it has close numbers to OEM.
Most people I see are buying the 305/50/22 as it has more variety and cheaper prices. I think that would be a good size to buy, though our stock rims which are only 8 inch wide are not normally recommended for such tire size.
But when I get ready to get new tires, I think I will buy 305/45/22, as some people have done on here.
2016 QX80 base. This one comes with stock aftermarket wheels. These wheels are getting common on the QX from the dealerships.
This one is 22 by 9.5 with a +16mm offset
Tires are 305/45/22
Just thought I should share that. I asked at the dealership and they could not tell me the details about the specs of the wheels, so I asked for one and looked in the inside of the rim and got this info.
Took some pics to share.
my post should not be confusing.
the answer is yes.
Looking for opinions as well for our 15 80 with 22" tires.
Stock replacement Bridgestone Duelers 275/50/22 are almost $1300 m/b out the door.
Toyo Open Country HT 285/45/22 are just under $950. Tire shop says this tire will fit and I've run Toyo tires on my pickup for a number of years with great success.
Any of you guys run the Toyo tires on yours?
305/45/22 is working for me on stock 22x8 rims.
My tires are Atturo Trail Blade X/T.
http://www.clubarmada.com/forums/showthread.php?t=24056&page=50
https://www.youtube.com/watch?v=eBnE1hHHevs&feature=youtu.be
