marctronixx
Staff member
kit to view DVD while in motion
All,
earlier i had mentioned there is a kit a fellow forum member was making that allows one to play DVDs and use the other controls that grey out while the parking brake is off and the car is in motion. it was initially made for the 08+ armadas.
i finally had time to install this kit and it works just as well on the 2012 (and 2011) QX. I had the guy build the kit because i am not savvy with those kinds of things.
the kit will cost $50-60 bux depending on if you want a lighted switch or not. shipping is included and also some zip ties.
you can also purchase the parts (couple of relays, diode, DPDT switch, wiring) and wire it up yourself. parts are about 20 bux or so.
what you will need to do, which is different from other modules on the market, is you must splice into the VSS and park brake wire behind the radio. this kit will give you full control of the DVD and other options whilst the car is in motion just as the other modules on the interwebs do. Again the only difference is you splice into those two wires.
I have used this kit in my 08 armada when i purchased it in 08 and it gave me reliable service up until i sold it for the 12 qx.
on the qx, i drilled a hole right next to the OBDII port to mount the switch and it looks like OEM. the iba button is there also... which i didnt know until a week or so after i purchased the car..
his name is Shane over at tintmasters: http://www.tintmasters.net/forums/viewtopic.php?t=5059
quality of parts and work is second to none.
so if you want other alternatives to higher priced options, give this a try.
All,
