ChesbayQX56
- Joined
 - Sep 28, 2016
- Messages
 - 18
- Reaction score
 - 3
- Points
 - 3
The volts on my 2013 QX56 have been fluctuating recently. The volts spike up to normal range when the car is started. After driving for a few minutes or sitting idle the volts average around 12.3 -12.1. If I turn the headlights on the volts go back up to the normal range. (I have been driving with the lights on) The battery is 6 months old and I have had it tested. I am thinking it is either the battery current sensor, relay, alternator, grounding, battery or an issue with the IDPM.  I am going to replace the battery and shield the current sensor. If this doesn't work I am going to remove the wire between the IPDM & the alternator. This should provide me with full time alternator volts.
Has anyone had this issue? Lots of talk about similar issues on other infiniti models.
Steven
Steven
