ABS SENSOR question
darrinswait
So I replaced (1) strut and axle/CV joint (RH) on my 2000 I30t...yay! (It SUCKED.) However, everything went back together fine. One side to go. Unfortunately, during the reassembly, I broke the ABS sensor off right where it bolts onto the "hub". Apparently, it's a costly part. I guess my question is what can I expect to happen when I drive the car again? I mean, obviously the ABS won't work on that particular wheel. Will this have any effect on the rest of the system?
Other than the ABS light being on, and presumably the ABS not working on that location, I can't tell that anything has been affected.
