Hello, first time infinity owner here. Traded in my Beemer for a "reliable" infinity 2011 QX56. My story is one of engine shudder and eventually having it strand me and unable to get to work. It would first present itself as rough idle right after a cold start and the engine wouldn't go above ~3000 RPM. At first you could then shut the truck off and restart it and it would be fine.  However, I still sent it into the shop after it happened and they though it was one of the VCT solenoids. So they replaced that (took a week) and gave the truck back. Within a couple of days it did it again. Back to the shop to have the other VCT solenoid replaced.. (Another week gone). After getting the truck back again, it lasted only another few  days and then it stranded me b/c it would not go over 1000 RPM / 10 MPH, and restarting it made no difference, had to call the tow truck.
Here is where the real fun begins.
The dealer had the truck for a week and could not replicate the issue. I called them on day 5 or 6 and re-iterated that the issue happens on a cold start and it you would know right away if you tried to drive it more than 150 feet.
On day 7 they replicated the issue and pulled a bunch of codes. They came back telling me it was the timing chain and a bunch of other goodies that would have to be replaced. Please note that this truck never made any of the whining or other noises reported here on the forum during cold startup.(other than then the electric fan test)
3 weeks LATER I got the truck back with 5k worth of parts (and that is with a 25% discount on parts) and 3k in labor. Thankfully all covered by the aftermarket warranty I purchased for the truck.
I was told that the cause of all this damage was the faulty OIL JETS for the timing chain area that were replaced with upgraded parts so this "won't happen again". I was(and still am) shocked to find out that this infinity had just rang up a 8k repair bill in the first month I had owned it. This is far more than I had ever spent on my M5!
Here is the list of parts they replaced in case anyone else needs the info:
CAMSHAFT ASSY-13020-1MC1E
SPROCKET-CAMSHAFT IN-13025-1LAOA
SPROCKET-CAMSHAFT IN-13025-1LAOB
COVER ASSY VALVE TIM-13041-1LA1A
COVER ASSY VALVE TIM-1304l-1LAlB
COVER ASSY-FRONT-l3500-1LAOA
PUMP ASSY-FUEL, HIGH-16630-1LAOA
VALVE ASSY-SOLENOID,-23796-JK23B
CHAIN-CAMSHAFT-13028-1LA3A
JET-OIL TIMING-13081-1LAOA
LIFTER-VALVE-13231-1MC5E
SEAL-0 RING-16618-1LAOD
SPROCKET:CRANKSHAFT:13021:1CAOA
SPROCKET-CRANKSHAFT-13021-1LA1A
TIMING CHAIN-CAMCHAF-13028-1CA4A
SEAL-OIL,CAMSHAFT-13042-3HDOA
TENSIONER ASSY-BELT-13070-1CAlB
PULLY-TENSIONER-13070-1LA1A
GASKET - ROCKER COVE-13270-1LA1A
GASKET - ROCKER COVE-13270-1LAOA
SEAL-OIL CRANKSHAFT-13510-1LAOA
SEAL-0 RING-15066-AR010
SEAL-O RING-15066-AR020
SEAL O RING (6.84MM)-15066-ZL80A
SEAL 0-RING-15066-1LAOA
RING-0-15066-1LAOB
SEAL-0 RING-15066-6N204
SEAL-0 RING-15066-75010
TUBE ASSY-FUEL-17520-1LAOB
TUBE ASSY-FUEL-17520-EZ3OA
o-RING - A/C-92472-N8210
o-RING - A/C-92474-N8210
GUIDE CHAIN TEN-13085-1CA18
GUIDE CHAIN TEN-13085-1LA2A
CHAIN GUIDE-13091-1CA1B
CHAIN GUIDE-13091-1LA2A
THREEBOND 1217F GASK-999MP-1217FPP
NISSAN LONG LIFE COO-999MP-L25500P
MOBIL SPECIAL 5W-30-5W30
BOLT-13094-AR000
BOLT-TENSIONER-13075-AR005
GASKET-46237-1LAOA
LONG LIFE ANTIFREEZE-999MP-AFOOOP
P0WER STEERING FLUID-999MP-AGOOOP
5,000 in parts
3,000 in labor
_________________
8,000 Total
You may notice that they had to replace the high pressure fuel pump too. (had not seen this before on this thread.) That part alone is 2 grand! The service advisor said "they don't have to replace those too often". I remarked that when it is buried 17 hours’ worth of work in the engine that it should NEVER have to be replaced..
So hopefully the truck will be fine now after being in the shop 5 weeks out of the last 8 I have owned it. Word to the wise, if you are going to get one of these used, make sure you get a warranty that covers these types of repairs like MaxCare did.
