Dread_Parrot
- Joined
- Sep 8, 2011
- Messages
- 194
- Reaction score
- 0
- Points
- 0
Bummer
Man, That's a shame Ronretro. I cannot believe they are saying there is no fix, there is generally always a fix. I mean its drive by wire, they should be able to put a isolation block under the accelerator and adjust the Length of the accelerator pedal?
Back in the old days there was an actual rod that attached to the accelerator and it went through the firewall to the Carburator that was on the motor. I could understand a slight vibration there.
Later the car companies used a cable that attached to the accelerator and attached to the throttle body. Now its drive by wire, a electrical signal. That doesn't vibrate.
I guess if you don't have the 'buzz/vibration' you are extremely lucky.
Marctronix let us know if you drive a vibrator version
Thanks for keeping us updated Ronretro. Appreciate it !
