primov8
Well-known member
Nice. Enjoy the new mods!Hey finally got to installing my stage 2 exhaust from Cajun pipes! Definitely a pain in the ass job.... But we got there. I did try something a little different from the instructions. Instead of lifting the engine(my engine mount bolts were seized) I removed the studs. It gave enough clearance for the headers to slip out. When installing the new headers it was tricky lining everything up and the lower header studs took a lot of fenagling to get all the way in and tight(the headerpipe denies an etorx socket access on the three lower rear bolts). In other words with the right tools this job might be easier without lifting the engine!
It is so true that the right tools, makes the job that much easier. Back when I had my 04 LE and did these JBA LT headers, it took me some time to get it done since I didn't have some of the tools I have now. With just the use of universal joints, universal sockets (14mm & 18mm), offset and flex head wrenches (14mm), got this all done in under 8hrs.
