G
G-124078
I'm hearing this issue on the 2011 & 2012 as wellManifolds and cats on 2010 and earlier armadas titans and QX vehicles are known for this.
exactly to be honest for the prices of all the top 4 I might just work down the list and see if any of them help me... worth a shot.Tried Cataclean. Didn't help my situation. I imagine it probably depends how bad the Cats are. For $25, it's worth a shot. Better than the $1100 I paid to have the Cat replaced.
a simple easy way to confirm the efficiency of both CATS its to check input and ouput temperature with a infrared temperature gun (harbor tools sell for $30) output should be hotter than the input, if lower or the same your cat its deadNo, I did not ask them specifically what process they went through. Probably a question I should have/can ask. At this point I haven't had the work done. I just bought the thing, so I have to replenish my reserves a bit to fork over the $2300.
A blind guess, but I'm thinking this might have been the reason the previous owner parted with the car.
Same thing here, CEL came on at 95,000 miles, 0430 code, put in a can of Seafoam in a half tank, drove it like I stole it until the gas notification came on for about 20 or so miles, a day or so later the CEL went away. Will try to keep you posted in a few months.Fixed Cat
I have a 2012 QX56 with 104K miles. It threw a P0430 a month or so ago. I reset it once with my scan tool. Of course, it came back once all the parameters reset. After getting a quote for $2,000 to replace Bank 2, I looked at this thread.
Somebody said put a can of Seafoam into a half tank of gas and drive it like you stole it. He got ridiculed and many pooh, pooh'd his solution. I figured, what do I have to lose. So, I bought a can of Seafoam for $7.99, dumped it in the fuel tank and drove it like I stole it. I mean, manual-shift-at-red-line beat on it, repeatedly. The light didn't go away... until I got back in it later and started it up. BINGO, no CEL.
Maybe it will last, maybe it won't. The bottom line is this. The QX56 SUV is an INFINITI performance vehicle. Between trips to the grocery store and the soccer field, put the pedal to the metal and let it fly some. Treat it with a can of Seafoam every 3 months or so. For now, I am going to get the emissions test to PASS and bank the $2,000.
Well, now the engine is misfiring and the CEL is blinking. Haven’t checked the code yet.Same thing here, CEL came on at 95,000 miles, 0430 code, put in a can of Seafoam in a half tank, drove it like I stole it until the gas notification came on for about 20 or so miles, a day or so later the CEL went away. Will try to keep you posted in a few months.
So can the 02 sensors just be replaced in the cats or still have to replace those. Qx56 2005Dealer told me to replace the catalytic converter and O2 sensor it's about $1,800. Once again the parts has been revised...both the O2 sensor and the catalytic converter. I had mine replaced shortly after 60k. It better last...no way I should ever have to replace a catalytic converter...this should have been a recall.
The reason they only replace the passenger side, which is bank 2 is because for some reason the catalytic converter on that side loses its efficiency causing the O2 sensor to read outside it's value...hence the check engine light..
Yeah, similar in my case. I believe the dealer clears the codes and you get maybe 100 miles before they pop up again. It's a very common issue with the 5.6 V8. I love my QX56, but had I to do it over again.....I probably would have passed if I knew then what I know now. And yes, I invested in about $4300 worth of new CAT converters (both sides), and labor. I also had to replace my rear pump for the air suspension. My local Infiniti dealer wanted $800 for that pump. I went to an independent mechanic and with an extended warranty I luckily bought when I got the beast, it was less than $400 for the pump and labor. I'm holding my breath and hoping the timing chain doesn't act up. I have 120K on my 2013 now.just bought a qx56 and yup four days after driving to home codes to replace fuel pump and both catilic converters 7Kdealer was no help. not only did I pay top dollar for a vehicle now it needs 4K in work total BS.
"I love my QX56, but had I to do it over again.....I probably would have passed if I knew then what I know now." I couldn't agree more.Yeah, similar in my case. I believe the dealer clears the codes and you get maybe 100 miles before they pop up again. It's a very common issue with the 5.6 V8. I love my QX56, but had I to do it over again.....I probably would have passed if I knew then what I know now. And yes, I invested in about $4300 worth of new CAT converters (both sides), and labor. I also had to replace my rear pump for the air suspension. My local Infiniti dealer wanted $800 for that pump. I went to an independent mechanic and with an extended warranty I luckily bought when I got the beast, it was less than $400 for the pump and labor. I'm holding my breath and hoping the timing chain doesn't act up. I have 120K on my 2013 now.
Those parts alone, roughly $1800. I did replace all the sensors and plugs and opted for Denso via Rock Auto. For the gaskets (manifolds and exhaust) I always stick with OE and bought them from infinitipartsdeal.net.@primov8 What was your cost btw?
Nice! An swapped VK56 Xterra is definitely one that stands out.@primov8, I called LMP and they said It comes in 2 pieces the header and the Y-pipe. Other than a small mod to connect the stock pipe to the y pipe it should bolt right in with no issues and not through any codes. I will look into CajunB as I had a VK56 swapped xterra and CajunB did a nice job. How ever I could only find products for the armada/titan. Ik the new armadas are basically QX56s but is all the exhaust mounting the same locations?
Thanks for the info just dont want to order and have to return.
