G
G-608917
Check engine light stay on and chassis error light gone. Q50 seems problematic
Same thing I’m dealing with right now does it make a humming noI at all?2014 Infiniti q50 RWD Driving on freeway doing 69 MPH chassis control system error popped up on the dash abs and traction control light illuminated as well I stopped at gas station turned the car off for a few minutes and started it and all lights were off drive about 10 miles and all 3 lights came back on. Has anyone ever had this issue?
I saw the same on my car today when driving down from cold weather. It was 24 degrees and the car was driving fine in the snow. Drove down and stopped for gas at a place at 46 degrees. Drive for about 10 minutes when the car stopped revving up and revs would fluctuate on their own. Pulled to the side and pushed the gas pedal down a few times and the revs were not responding. Turned it off and back on and it would lose revs seeming like it would turn off. Then the chassis control error light and check engine turned on. Turned the car off and let it rest for 5 minutes. Just the check engine light was left on then and the car started driving fine. Does this scenario sound familiar?
Did your car shake with it?2014 Infiniti q50 RWD Driving on freeway doing 69 MPH chassis control system error popped up on the dash abs and traction control light illuminated as well I stopped at gas station turned the car off for a few minutes and started it and all lights were off drive about 10 miles and all 3 lights came back on. Has anyone ever had this issue?
I'm going throught the exact same thing in the exact same order. Wow. Now my chasis light is on and my steering is very wonkyCar was running and working perfect. -40, My battery died. I put the charger on it and started right up. Holds a charge and starts every time. can even drive it but the steering is wonky. like manual steering. But also, now the chassis control error message is on as well as power steering warning light, brake system warning light, Direct response hybrid light, forward emergency braking system. There's no way all this failed because the battery lost charge. Anyone know if there's some reset sequence for the computer?
