The tranny fluid had never been changed on my 2011 with 100k. I opted for a fill rather than a flush for cost reasons and I figured I could do it myself. Replaced my transmission fluid using Valvoline Max Life. I used the garden sprayer method. I attached the sprayer to the adapter piece that attaches to the filler hole and filled the exact amount that came out of the drain hole. I read somewhere that the full point is when the fill hole begins to flow out when filling. But the amount that came out when I drained was about 2 liters over what would have been to the point where it was draining from the fill hole. Which is right? Would hate to over/under fill.
SUV runs great btw. Before it had a bit of shutter at low speeds.
