not fully appreciated the heavy rain you had, it could have been something that was soggy--a wiring harness or something else.
the obd system will log a code and not mention it (it wont throw a CEL light) unless that code pops up again, then it will alert you.
since you have not seen a cel, this could have been a one off incident (due to the heavy rain).
still, something made the car sputter a bit, so maybe check any harnesses, coil packs (over the spark plugs) or anything electrical under the hood to see if there is anything visible to your eye.
if you have access to a code
scanner, its a no brainer to use it. autozone and stores like that have them and they usually would do it for free.
if you want one yourself, there's these bluetooth dongles you can connect to your phone and car (10 bux) and you can get a 5 dollar (or free) app off the app store on your phone to read the codes anytime-p-and even clear the cel lamp.
