Offset
Supralative
From what I have seen the factory offset is +30 correct
Anyone with spacers and or after market wheels.....
What are offset are you running
I want to find a set of wheels that I set as close to flush with the body if possible
Is +20 ok or too much
Issue you are going to have is the fender flares because they extend out it is really hard to get the perfect offset for this truck. I have a set of Giovanna Dakar 6 22's and a set of 26" Dub Ballers...
Yes you can do a +30 offset and get away with it. To look right you need to run two different offsets if you want to be flush.
My 28" wheels are +25 offset and the front is closer to being flush compared to the back.
I'm running 22" KMC Slide in 22X9.5 ET(offset) 15 with 305 tires.
PERFECT fit, flush to the fender but still ok when the suspension sag after attaching my travel trailer.
So, you should be ok with an offset of 20 if the wheel is not wider than 10" and tire not wider than 305.
Can you guys post up pics of your set ups
Thanks for the replies as well
those KMCs are choice.... was gonna snag some but im saving up for a synthesizer.. ;)
#priorities
Here is my QX with 295x25x28 Pirelli Scorpion Zero Asimmetrico
All season tires.
[/URL]
