jblountak
Hi all,
My wife and I just picked up a 2010 QX56 4x4 over the weekend. It has 140K on it, and is a little rough around the edges, but for the most part in good condition. There are a couple issues, that I have questions about though.
first: The trim in the drivers side headlight that normally covers the parking light has fallen out of place and is sitting in front of the low beam...is there anyway to fix this without baking the headlight apart or buying a new one?
Second: The steering has a bit of a vibration at speed, are there any steering components that wear out faster than others, or at the age/mileage is that just to be expected?
Third: The air suspension in the rear is completely collapsed, and the compressor doesn't come on...Is the compressor usually the culprit in this situation or is the ride height sensor more likely the cause? (There is no check suspension light on.)
Fourth: I usually like to add a transmission cooler to vehicles of this age...is there a preferred cooler for these rigs?
Finally: Does anyone know of a plug and play remote start for the 56? I'm not afraid of wiring, but on something with this many gadgets, and can-bus system, I would prefer a plug and play as opposed to splicing wires.
Thanks.
I also found yesterday, that the button for the front and rear sonar sensors is always flashing...I'm guessing a sensor went bad?
Thanks.
