marctronixx
Staff member
cant agree more with this.
Driverside and passenger only unlocks. I was thinking it could be the bcm alsopossible BCM or faulty switch.
that's your first starting point. anything else is speculation.Once I get to my scanner I multiple codes pop up
2004 qx56 on the gauge cluster what is it supposed to read out to normally?
2004 qx56 what does the H and L mean on the gauge? High and low pressure? Also where is it supposed to be at normally? When I accelerate it goes up and of course deceleration goes down
Still can't find the wire
When I put it in reverse it only shows back up lines and beebs when objects are to close. It doesn't give picture of what's behind. I was wondering if its a bad camera or bad wiringwhat?
