Infiniti I30 is producing excessive white smoke from tailpipe on start up. 3 years
pooksned
now. ? 2000 infiniti. No one has been able to find the problem. It happens on an average 2 times out of 10 starts. Help me
Does the smoke almost instantly disappears when it exits the exhaust or does it linger? If its lingers your probably burning oil, if it almost instantly disappears your engine is just warming up.
There are two things that you could be burning; coolant and or oil. Check the level of both over time. If the level of either goes down than that's your problem. Cars can normally burn oil which requires additional diagnosis if you're burning oil.
On initial start up you may some moisture in the exhaust system which is burning off. That is normal. My car does this sometimes.
