Hi, I hope someone might know if the gear ratios could be changed from 3.36 to the 2.97 in my 2006 QX56. My front diff is on borrowed time and I just bought a used titan front diff that only has 55,000 miles on it. I checked with my local nissan with the vin to verify ratio and she said the titan had the 3.36. After getting it home and checking the ratio I find out its the 2.94 ratio. I was looking at used ones and noticed that the newer QX's are running the 2.94 and was wondering why they changed and if I should keep this front and find a back with the same ratio and change them both. Does anyone know if they are running same transfercase and transmission as the older qx or is it different and why they changed to the lower ratio. Any info would be appreciated.
Thanks
Rob
Thanks
Rob
