Dash Warning Lights
CBlake
Hey all-
I had this pop up last night. All these warning lights came on and stayed on. I stopped and shut the the truck down and restarted and they came back on.
I let it sit about an hour or so, and they still came on. I then let it sit overnight (about 7 hours) and they were off this morning and didn't come back on during the drive to work.
Has anyone encountered this? I assume a sensor is messed up?
my g35 lit up 3 or 4 lights once when my brake pads were worn (ABS, VDC, slip, something else)...how old are yours? i'd take it in either way.
low oil, coolant... check your DTC codes (if any ) at the obd port.
when was your last maintenance done?
how long have you had the car? only owner? used ? certified from infiniti?
Brake pads are in good shape.
Oil is good
Coolant is good
No codes
Maintenance back in february
I've had it about 1.5 years and not the first owner, not certified, etc. private seller.
check codes at the obd port. could be bad delta brake sensors at the master cylinder. just a guess but something i've seen on other armadas/qx's
No codes, but I think i found the problem. Bad rear wheel bearing unit.
I'll update if that's not it.
Thanks
