PetitFrereArmada
- Joined
- Sep 23, 2016
- Messages
- 72
- Reaction score
- 1
- Points
- 6
I used these sensors off amazon. They are identical to the OE sensor since both are made by Bosch
Bosch 17006 Oxygen Sensor, OE Type Fitment https://www.amazon.com/dp/B00EZQJA8I/ref=cm_sw_r_cp_api_6l4dzb3T6C3EX
I recommend the OE Manifold / Cat and gaskets as well. I also highly recommend you replace the manifold nuts as well and coat them in anti-seize
Tell me more about this ECM reset, as in what is it just to clear the code or is it something more along the lines of a reprogram?
I am planning on buying bank two and replacing it with in the next few weeks, I love the "having the mechanic call" idea LoL
If you do bank 2, please, can you take some pictures of install and share? I think it would be great to look at.
And thanks a lot for this more detailed info. Based on your advice, I am going with everything OEM, except the sensor which I bought aftermarket. And I like your idea of replacing all the studs and nuts. All studs and nuts would cost less than $20. I am buying all brand new oem.
I did a search and found Bosch and Denso both sell that sensor. I decided to go with Denso since they seem to be more reliable.
I have bought these so far...
INFINITI 140021LA0C GENUINE OEM EXHAUST MANIFOLD
Nissan OEM Exhaust-Front Pipe Stud 14064JG30B
20692-24U0A GASKET-EXHAUST
Denso 234-5095 Air Sensor
INFINITI/NISSAN 14036-1LA0A GENUINE OEM EXHAUST MANIFOLD GASKET
If I do not forget, I plan to take pictures of every one of these items that I bought and post too on the forum. The pictures may be helpful to some other people.
Someday within the next 2 weeks, when I have time I will go to my mechanic to have him do the install.
I really find myself just hating seeing that check engine light on my car. But since the light came on, I have put over 4,000 miles. I took a 2,000 miles road trip to Big Bend with the check engine light on. Well, I had it off by disconnecting battery, but it would come back after 1,000 miles. I also took a 600 miles round trip this weekend to Dallas with the check engine light on. Car drives with no problem.
If I did not have a major road trip coming up in July, I was almost tempted to leave this car as is and drive it for a while with that light on.
My Maxima had the same light on for catalytic converter and I drove it like that for over 2 years and over 40,000 miles. Car drove like a dream. When I went to pay and change the cat, it was all gutted out. But did not affect my Maxima. I had my mechanic install the new cats for my Maxima. As of today, my 2008 Maxima has 212,900 miles and this morning on my way to work, car gives me great performance and accelerates as if I am in my QX. Still in top form.
