Catalytic converters help!
Wlroberson
I have a 2011 Infiniti QX56. After I purchased the car the engine light came on for catalytic converters. I have driven it for 2 1/2 years with no problem with the light still on. I had a misfire one day and took it to my mechanic. He said that I was overdue for an oil change so try that first bc it could be causing my car to run rough. I decided to have the cats fixed which was replacing front 2 and cutting and straight pipe the back 2. After 7 days of driving now my car will turn on and idle fine but when I put in gear it jumps skips and runs rough and engine light blinking. Please need some direction! Thanks!
Your coil packs are probably going, which is bad because if you are sending unfired fuel down to your cats, you are ruining them. Blinking CEL = BAD and you should avoid driving it if possible. You may also be up for the plugs being changed out. If it's been a while, I'd change those out at the same time of changing the coil packs.
