Gumbey
Left for a week, battery is dead
I left on vacation for 9 days and when I returned I wanted to take my QX to the store to pick up a few items.
Well low and behold, the thing wouldn't start. It had some power, but it was extremely low and it wouldn't turn over. With each successive try the power was dwindling.
I had to call Roadside to come give me a boost, and it started up right away. After it started I noticed the 4WD light was on, which I though was weird as I hadn't even driven it anywhere at that point.
I took it for a 5 min drive to ensure the battery got charged up and brought it back into my garage. I restarted it and the 4WD warning light disappreared, so maybe it was an issue with the battery being drained.
This is not the only problem I've had with a bad battery. About 8 months ago this happened and Roadside could not even get it started with a jump and it had to be towed over 400 kms to the nearest dealer. Once they looked at it, they determined the battery was bad and changed it out under warranty(that was a really expensive battery!!!) So now I need to call the same dealer and ask what they think may be the issue.
Second issue is the battery itself. Now that it was virtually drained do I absolutely need to get a new battery? I hear and read different things regarding a drained battery. Some say change it out as it will never hold a full charge again, others say its still good.
Finally, why in 9 days did my battery die / fail ? Yes it was in my garage, it was also locked with the FOB like I would do anywhere. I don't believe 9 days is an unreasonable timeframe to keep the battery from discharging completely. However, according to the rep at roadside it was too long...WTF.
