ConfusedQx56owner
- Joined
- Nov 14, 2021
- Messages
- 4
- Reaction score
- 0
- Points
- 1
Hello everyone. I have a 2011 QX56. 300,000k. I just put a new engine harness in. Then engine went. So I had the dealership put a 2013 with 44k The starter was shorter so that’s new. They never changed my fuel injectors. All cats are new because they said it was that. Then one of the specialist said it was fuel pump which they changed. Then started driving it and the Map and Maf sensor code went off. Went back and they replaced both sensors and PCV valves. Still same code is going on. They had it for 6 weeks and still can’t figure out why code is coming back on. They think maybe the engine doesn’t work with ecm of 2011. Because it’s the only year with Maf and Map. I can’t buy a new ecm because it’s discontinued They just gave it back to me with their hands up. It drives fine but RPM is high around 1k. Going through more gas it seems. Any ideas? Brought it to a small shop and they said it’s the fuel injector seals. But the dealership said it would come up lean code. Need help? Put 15k in the last two months. Thought it would be cheaper to keep it then buying new.
