2017 QX80...
Legendary70
Hello all.
Just picked up the truck last night from Carvana. I have a few questions and any advice from veteran owners would be great.
How do i get the 2 monitors on the back of the front chairs to play something? It has a CD player on the console. Is that the only way to play something? If so, will it take over the entire sound system?
Not sure if it ain't working or i am doing something wrong. the cruise control does not initiate. I push the on off switch and I see the cruise on the dash but when push down to set it does not work. any ideas?
Also when I open any door only the 2 front light inside the cabin come on. pretty sure all the lights in the middle and rear should come on as well but do not.
My apologies I dont see an edit button. Is there a rear cabin filter for the rear blower? cannot find anything on YT.
A little late on the reply so you might have already answered these questions but if not, here's my 0.02.
1. Yes, you insert a DVD into the "CD player" console to play it on the 2nd row screens. It will also play on the front console screen if the e-brake is engaged. To start the movie, you can use the remote or the controls on front console screen. The remote is easier if you have it.
2. I hardly ever use cruise control but it sounds like you are doing it correctly. I'd check your manual and make sure you're following all the correct steps.
3. Yes, all the lights should come on, except for the one over the 3rd row/cargo area. That only comes on when the rear hatch is open. I doubt all the bulbs burned out so you likely have a blown fuse.
4. There is not a separate rear cabin filter. Just the main one behind the glove box which you can find several YT videos on.
Congrats on the "new to you" ride! I have a '17 and just picked up a '19 as my '17 was in an accident. I'm still getting used to the '19 as the steering feel is different. It may just be familiarity but I think I like the '17 better.
