I'd start with the P2101 DTC. Before having to spend $$$$ for a new throttle body, get yourself a can of throttle body cleaner. Disconnect the pigtail connector fand the air intake tube from the throttle body. Give it a good cleaning by spraying directly into and all over the interior of the throttle body. The butterfly valves can be moved by hand and clean around those areas too. Me personally, I'd remove the throttle body off from the intake manifold to clean it thoroughly but you would need a new throttle body gasket.
With the cleaning done, you'll have to do a throttle body relearn. If you don't have access to a full range
scan tool to do the relearn, then a video like this pretty much shows a DIY "how-to":
