QX_Jean
The rear suspension is the reason I sold my 2011...
Hi with Dudley, I have a 2014 qx80 I have a problem with my automatic rear suspension is not activating and bring the ride back up to high. I've checked the fusible link and relay and those checked fine. Has anyone else experienced this?
Where can I adjust this
Thanks
I am having trouble with the rear of my 2012 QX56 sagging horribly immediately after getting it back from the dealer performing the timing belt recall. I'm being told that being on the lift with the engine turned on (when the recall was done) could have caused some malfunction/damage. I'm not a car expert so can anyone more versed in these things help me out here??
I just replaced my compressor and nothing happened. It never kicked on. Did you get yours fixed?Good day guys....
Picked up my 2011 QX56 and I think the rear should be higher than what it is right now.
Before picking it up,the dealer changed the compressor and I thought the height will auto adjust so I didn't say much but it's been a couple of days and even went and picked up a couch and it still sags.
I will attach some pics for you guys to see if this is normal.
Also a quick question,for the year 2011 QX56,where are the air bags,are they built into the shocks or should be separate and visually visible ?
I crawl underneath the truck to see whats going on but couldn't see any airbags.I will appreciate some pics.
Thank you.
As you see,the rear is pretty low compared to the front.
Good day guys....
Thank you.
Does it matter if it has the HMBC?Strut master makes a kit with new shocks and springs to get rid of the air suspension.
2012-2018 Infiniti QX80 / QX56 Rear Conversion Kit AWD (QX1RB) - Strutmasters
Hi i have a same problem I change the air bags and they told me now i have to change the pumpI just replaced my compressor and nothing happened. It never kicked on. Did you get yours fixed?
I thought it was only there to level heavy loads??? I'm assuming that our beast does not use the air suspension like my Audi A8 does???I did some searching, but maybe I used the wrong words...
I have a 2012 QX56 and the automatic rear suspension is not activating and bringing the ride height back up.
