2012 QX56 Rear Suspension Bump Stop Removal
dh1010
I'm looking to replace the stock bump stops with Timberins for rv towing. The nut on the bump stop looks to be encased in a void that's welded on all sides. How do i get to this nut and remove? Do I even need to get to the nut or is the bump stop removed a different way? Thanks.
You’ll need a 80mm deep socket or spanner wrench to remove the OE rear bump stops.
Just to be clear, the bump stops are mounted on the frame not on the coils. Does your 2 options apply? Thanks
Correct. The rear bump stops are mounted on the frame, right above the rear UCAs.
Follow up questions. Do i need to screw or pry off the bump stop rubber first? or just turn off the whole thing with the socket or spanner? TIA.
You just have to turn the entire bump stop; just place either socket or spanner right on the 6 point/hex flange of the bump stop and muscle the rest.
Great! Thanks for all the help!
