jordan30107
- Joined
- Mar 19, 2023
- Messages
- 1
- Reaction score
- 0
- Points
- 1
I have a 2011 QX56 with 186,000 miles. recently had CEL with P0087 and P0090 codes displayed. Replaced the HPFP lifter and it was obviously the issue as it was worn completely through on the bottom. Following reassembly I cleared the codes and tested the vehcile. Vehicle drives and operated correctly however not there is a P0088 code that has came up. I definately could see the HPFP creating the previous codes as it was functioning properly however the swap went perfenct and no issues. What would cause a Fuel Rail System Pressure - Too high code to occur?
