2005 qx56 rear captain chair removal
jbug1
alabama
Hello !! I have a 2005 qx56 with a bad fuel pump. Can anyone please instruct me on how to remove the rear driver captain chair to access the fuel pump. I have already located the pump under the seat. Any help would be greatly appreciated. There are no videos out there showing how to remove the seat.
https://youtu.be/WzorU0eCCs8
That’s for a 2010 armada with captains chairs. Your cars captains chairs should be the same since they were all made on the same line.
Looks as if you don’t need to totally remove the seat... just flip it forward.
You can also find the recall bulletin online and look at the steps the dealer would take to get to the tank.
I recall some people getting their carpet cut..others stated the ire tank was removed from the bottom of the car.
But if you don’t mind cutting the flap, jus flip the seat forward as others have done.
If you want to see more videos, search for your year but subtitle “armada”, so “2006 armada fuel pump removal” or similar....
Thank you sooo much for your help !!!!!
Hi thanks for your help. Would you be so kind as to reposting the pics to this thread that you provided in your earlier post. Some how the pics disappeared. Thanks !!
