When I turn on the air conditioning in the car, it will put out very cold air (awesome). However, if I turn it up to the 80s and above, it shows the air flow going to the bottom (which means its going to blow hot air to heat up the car), but it still blows out freezing cold air. It will only blow HOT air when the climate control is set to 90 degrees. Any ideas?
