DelusionTrigger
- Joined
- Feb 24, 2024
- Messages
- 3
- Reaction score
- 0
- Points
- 1
Hello. I have an 2002 Infiniti I35I. have an issue where whenever I pull the turn signal switch to do a left turn.. It blows the fuse. Doing a right turn is fine. Changed turn signal bulbs and it worked fine and didnt blow the fuse... until I went back to turn the car on a few minutes and it blew the fuse again. hazards work fine. I tried to do a different method where I put a new fuse in and pulled the switch slightly down to use the left turn signal and it worked fine. just only when I pull it all the way down it blows. I'm not sure what it is that could be causing this
. I have checked for any shorts and could not fine any. I'm not sure what to do?
