Trim around wheel wells
cbkqx56
Has anyone had problems with the trim around the wheel wells (its on the outside, not inside)? My 2011, which i purchased used, seems to have a number of broken clips which makes the trim loose on both sides in the front. Can i just replace the clips, or do i need to replace the entire trim piece?
That is the fender flare you are referring too? I had 3 out of 4 get replaced under warranty due to the clips breaking or separating from the body.
yes exactly. did the dealer say only solution was to replace the whole thing? i see i can buy the clips and whatnot online, looks like a $10 fix.
