Note to all on tire wear. I’m hit 40k miles recently and just put on two new rear tires, tires were replaced just 20k miles ago!
1. rotate your tires religiously on this car, if not, they will be eaten up quickly!
2. DO NOT set rear camber to factory specs! Factory specs are set for toe in so inside of tires get more grip in curves. Problem with this, excessive inside tread wear!
Not sure if Infiniti dealer will set your camber outside of factory specs, but my tire guy did happily for me with my approval, and I see no noticeable difference in handling performance.
