sunvisor lights 1997 I30
dlgone
Hi, my sunvisor lights don't work on either side, not sure if they ever did. what and where do I check for first?
Thanks
not sure how to open the plastic covering, i suppose with a flat panel screwdriver, thinking it may be a fuse as well, since I thought it was unlikely all 4 would go out at the same time.
Thanks,
Dennis
I pried open the casing and the light is actualy a fuse? looks ok?
you can also unscrew the visor where it mounts to the headliner and there should be an electrical connector you can probe for voltage.
