straylight
- Joined
- Jan 12, 2013
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I have an 1997 i30. It's exhibiting some weird symptoms recently:
I've taken some steps to isolate the source of the problem:
Does anyone have an idea what the problem could be?
- While driving, occasional bursts of clicking come from in the vicinity of the column/under-dash area
- Sometimes when starting the car, the starter will engage as soon as the key is turned to the "On" position (before reaching "Start").
- Sometimes when parking the car, when shifting through/into Neutral and into Park, the starter will engage. If I attempt to go forward and/or back a few times, the symptom may stop.
- Replacing the ignition switch (just the switch, not the column components) had no effect.
- Moving the key during operation has no effect.
- Moving the shifter without moving the vehicle has no effect.
