Hello,
I recently had the recall done for the timing chain on my 2013 QX56. Since I received it back from the dealer I now notice a slight, annoying vibration when I am at a stop light or simply in park while the car is idling only when the AC is on. Every few seconds or so I'll get a vibration. Initially when I got the car back it also had a slight surge when I was in drive gear and holding the brake at stop lights. I took it back to the dealer and they did some type of programming to correct that issue however I still have the annoying slight vibration. FYI I recently purchased the vehicle used a month ago, only had it for a short time and when I took it to the dealer to get checked out before buying they advised me of the timing chain recall so I quickly took it in for the work a short time after my purchase. I'm not even sure if it did it before. Has anyone experienced this to be normal?
