Removing crankshaft pulley
darrinswait
I just found that my crankshaft pulley is bad...the outer part is separating from the hub. Other than replacing it, I'm guessing there is no real way to fix this. If so, please advise. Otherwise, are the threads on this just standard RH or are they LH threads?
Thanks,
Darrin
The threads are LHD. I had to use a mapp gas cylinder to heat up the nut to unscrew it.
