Thanks for this info. The Nissan part number is 284a1-7s000 l. Is this the entertainment center area that will require to be taken apart.there is the CCU that is in the rear back drivers side section, behind the interior finisher. there is the camera module that is a part of the entertainment system and BCM.
this is the av section from the 2011 qx. should be the info you need even if you have a later model.
