Sometime in the last couple of months, I noticed a subtle, but slight change in the sound of the engine on startup. Normal engine startup is smooth and instant. Now there is a very, very slight hesitation and a "slightly off sound", a little like "lope" from an aggressive camshaft in a hot rod engine. The engine seems to sound normal after startup.
I recorded this sound clip linked below, hoping it may be more helpful. Around 5 seconds in, is a good example. Unfortunately, the sound didn't come through as clear as I would like. There seems to be a lot of "airy" background noise, that is not present when hearing the engine run directly.
https://soundcloud.com/david-cramble...ti-qx56-engine
I have seen references to exhaust manifold cracks in the Armada, QX, Titan, etc - but none for this late (2008) of a model year. The truck has 120K miles on it now. I recently had new NGK Laser Platinum (factory spec) plugs installed. The sound existed both before and after the new plugs.
