the transmission seems to slip in and out of gear. It works ok with overdrive switch off. when you accelerate hard the rpm's goes to max but transmission not engaged, until you throttle back. Even at lower speeds it seems to engage and disengage. Also I can hear a faint chirp as it engages and disengages.
I am looking for directions for troubleshooting
The fluid is slightly brown but not burnt
Thanks for your input
