i looked into this a couple of months ago. i spoke with someone that had a lot of apple product knowledge. he said he thought the only way for it to work was to use an ipad that had a 20pin connector. there is an adapter from the 20 pin connector to composite cable that should work. according to my source, using a lightning to 20pin adapter and then 20pin to composite adapter will only supply audio. hope that wasnt too confusing. what i ended up doing was buying a cheap android box with a composite output and buying a 2.4 ghz wireless remote. the box stays inside the center console and hooks up in there. i ran power to the plug behind the center console to have the ability to control power.
