Infotainment system upgrade with Bluetooth audio, touchscreen, USB input, etc for Infiniti 2007+
Xanavi.net
Estonia
⚙️ This kit is based on the Clarion Premium 08IT-X9 genuine hardware, the same system is installed in 2010+ Infiniti cars with max. trim level
⚙️ Possible to do this upgrade on any specs and trim level (if your car doesn’t have a sat-nav/touchscreen display, you will get it)
⚙️ EX/QX70/FX/QX50/Q60/QX60/M/QX56/JX/Q70
What will you get:
✅ The same system as in 2010+ (max. trim level)
✅ Plug&Play installing using the exclusive wiring harness, no need to cut the car’s wiring
✅ OEM equipment
✅ Latest map data with the Birdview function
✅ Voice guidance
✅ Voice recognition
✅ Using this upgrade we can do the conversion (example: You bought Infiniti EX35 but you live in Bulgaria, after this upgrade you will get the Bulgaria specs system)
✅ Available the versions for the USA, Canada, Europe, Australia & New Zealand, GCC, China
✅ If you have the system w/o sat nav and touchscreen, you will get it
✅ USB input for playing audio and video files️
✅ Bluetooth Audio
✅ Possibility to connect add-on devices (Android unit, TV box, MirrorLink etc)
✅ Possibility to connect the cameras if your car doesn’t have it
✅ You don’t lose any functionality
✅ Worldwide delivery
✅ A to Z support
✅ A 2-years warranty
facebook.com/xanavi.net
Instagram.com/xanavi_eng
+37255562274 WhatsApp/Viber/Telegram
xanavi.eng@gmail.com
