Infiniti j30 problems..?
Dick D
my 1994 j30 infiniti has a coolant slightly leaking from the radiator plastic top part. i used some super glue to stop it , but is it gonna be for a while?
Next thing is when i start the car, sometimes the engine dies out, if i do not press a gas pedal, is it a problem with a fuel pump?
then, when i accelerate, there is a considerable vibration from the hood. I was told to have transmission mounts replaced.
so many things going on with my junky infiniti, can anyone help me out??
get a new radiator, your fix will fail..... when? tomarrow or sometime soon.
prob with the fuel pump? prob not, when was the last time you had a tuneup, intake cleaned, and IAC cleaned out? prob not for a while.... try that (or even better, your fav mechanic) instead of throwing parts at it.
if you were told your trans mounts were bad.... um, maybe you should fix them! or live with the vibration
and yes, the J30 is based (sorta) on the 300zx and they are upkeep nightmares. If you like the car, fix it.... if not let someone else deal with it
