How to remove rear door panel to fix window in a 96 Infiniti I30?
Bill R
The window does not go up - I think it is off the track.
This is relatively easy as I have just done it to get my window back on the track. There is a single screw in the bottom of the door handle. You'll need to pop the cover off of it and use a phillips screwdriver to unscrew it. Next, pull the panel from the bottom of the door. work around the sides to the top of the door. Reach in and release the wires to the power window switch in the door panel. Pull the latch to open the door to allow the panel to move outward. The plastic holder that wraps this handle my pop off. From here, just slide the door panel straight up and it should come right off if you've pulled it out from all of its connecting points.
