How can I tell if an Infiniti I30 has limited slip differential?
turn off the traction control, and stand on the gas. If you feel it jump or lurch, then take off without wheel spin, you got one.
I have a 99 I30t...
On your Firewall there is a silver tag (on the pass side)... A little more than halfway down on the tag there is a section stating "Trans"...the first group of numbers will end in either a V or an A. If it is a V, then you have LSD, if it is an A, then you do not.
Cheers
I have a 99 I30t...
Cheers
Mine ends with B
