Engine dies
foleyit
I was sitting at a light this morning and the engine shut off. It didn't want to start after several tries. Pushed it over to the side. Tried one more time and it fired up no problem. I let it idle again when I arrived at my destination only 3 minutes later and the engine died again.
I assume that if the fuel pump was failing it wouldn't have started up again. I question if it is the fuel filter.
Has anyone experienced anything like this before?
If anyone cares to know...the IPDM (Intelligent Power Distribution Module) failed and needed to be replaced.
How did you know it was this? Was the problem similiar to a battery/jump start engine die? Or fuel die?
