Engine air filter Q70
bbqbrisket
In researching prices on engine air cleaners/filters, I see several sites says change requires 2 filters.
I know one is located up front just back of the radiator on the drivers side; a very very easy change out.
I'm puzzled where the second one would be if it's true it needs 2.
Can someone advise.
thanks
No one likes to answer questions around here.
There is two on the 3.7 anyway. If you found one, look in the same spot on the other side of the engine.
Aftermarket is very limited for filters. I've pretty much only found K&N replacement filters and not CAI.
Yes, you need two of them, change them is a relatively operation, a 1 minute job.
There are two intake runners one is at the front right of the engine bay, the other at left, you won't miss it.
Hope this helps
