LED's
I wonder if there are some good LED's you can use?
Make sure you ( you already know this, turn on Low beam and switch on the fog lights and put a voltmeter on the center tab of the light socket. (don't touch the sides while touching that center with your voltmeter probe.) sparks.
make sure you get 13 volts, if not check that fuse under the hood in that black box next to the battery.
could be something crazy like that fuse, since both are out.
If bulbs I usually get one to go first, but both can go at the same time.
Its always something,
Those fuses are labeled I bet under that box cover. I'd go look for you, but wifey is driving ours today.
let us know what you find.
Parrott
