Attempted hijacking
samarik777
Hello, everybody. An unpleasant story happened, I went out in the morning, the car has two front windows open, the lock latch is broken out - in other words, an attempt to steal was. The car was not stolen apparently someone spooked or maybe amateurs got))))) Now the problem is that the car does not respond to the key, when you get in the car and press the button - nothing happens. If you insert the key in the key place and press the start button - lights up the dashboard, but the car does not start, the starter does not turn at all silence, and I do not see that the light bulb burns red with the key. What to do in such a case? I understand they tried to flash but not successfully, and my key is also erased, but why then, if the key is inserted the dashboard lights up? How can I make it see my old key and start? Thanks.
