Anti skid ligth
Marcgotti1965
I have a 2013 Q x56 and the anti-skid light comes out and the dashboard which causes the rear brake to lock in I turn off my truck go about my business for about an hour to come back in the truck works fine no light on the dashboard I’ll ride it for about an hour and the light will come on and will start like in the rear brake again please help does anybody know what I need to change
difficult to understand your concern without the use of punctuation. lets see if I can understand,
so you have an anti skid lamp. ok. have you done any mods to the car at all? electrical or mechanical. did you just purchase or have you had it a while?
have you had the obd port scanned to see if any trouble codes appear?
are you saying when the lamp comes on the rear brakes lock up?
Thank you for responding
I am very sorry about the punctuation. Yes I have an anti-skid lamp on my dashboard. I had the car for about three years and I recently had to do the catalytic converter‘s along with a few sensors that needed to be done on the engine. After paying the mechanic and driving it for two months everything was fine then the light suddenly appear on my dash for and I noticed that every time It lights up the rear brakes will start putting pressure I saved a car or star light slidinIt lights up the rear brakes will start putting pressure as if the car is skidding
Sometimes I turn on the car and once all the lights at the starter turn off that one lady stay on in the car will not move
I am a truck driver in as soon as I get home I will pick the car to get the scan done see if any calls will come up
id take the car back to the mechanic who did the work and have them inspect their work . its been some time since you had this done im aware but since they were the last to touch it they should inspect it.
you need to see if you are getting any error codes so you should have your obd port scanned with a scan tool. this is the first step to determining course of action.
Well I wanna think everyone that read my tread finally came in and took the truck to the dealer it turned out that the calipers were not retracting and the ball bearings wear worn out enough to make the tire shake and that sets off the antiskid sensor which make the brakes go on the dealer will change it all new parts new brake pads new rotors new calipers new ball bearings for $3000
