Hi guys new to forum
just got a 08 QX56 with 140K on it. I'm in houston TX
2 issues i need advice on please.
1.) Airbag light is flashing. I tried the reset method by clicking the key on and off about 4 times and it worked for about 4 minutes. I took it to a garage and he said he sees the codes for module issues but he said he doesnt know how to fix it with out buying a bunch of parts and putting it in and take it to a higher end garage. I took it to a second garage and he said maybe the airbage wire in the steering column is bad but again he said he's not sure until he takes it apart. So what should I do? any body know a good shop?
2) tpms light is on, the indash display isnt connecting to any of them. I used a TPMS reader to check the tires and it showed FL and BL tires had a signal but FR and BR did not have a signal, my reader was not able to reset the tpms and recommened advance equipment. SHould i take it to costco, they quote about 70 per tire parts and labor. do they balance, rotate and do alignment? any good mom and pops for this?
thanks in adnvace
Jr
thanks in adnvace
Jr
