Adding daytime running lights
Boss_Rob
ON
Hi all,
I have a 2005 QX56 and I want to know what fuse/circuit under that hood can I splice into to add LED daytime running lights.
I want to splice into a circuit that is only energized when the engine is on so that the lights come on when I start the truck.
Thanks
just look at the fuse panel diagram in your operators manual. find a relay in the ipdm thats energized (i,e, petrol pump) and tap into that.
whatever circuit you use, fuse! :)
Thanks, I bought a product called Little Fuse Add a Fuse Mini.just trying to figure out the best fuse to plug it into.
